spieng89
- Jun 30, 2015
- 172
I have a project where every structural bay will be a lateral frame going in both orthogonal directions due to member size constraints. It's an array of columns and beams in a typical frame pattern, 1 story. I am trying to justify not having a diaphragm element e.g. metal deck as well as no rod bracing as seen typically in PEMB structures? My justification is there are no collection elements, therefore a diaphragm is not needed to transfer load to the lateral frame. Am I envisioning the load path correctly?
