I am involved in a project where the client will test equipment. One test means that high altitude will be simulated and that means that the test room shall have a very low air pressure.
That obviously means that walls and roof will get a high "load" due to the external pressure. But for things to work as intended the "room" can't leak air, at least not significantly.
Does anybody know of a definition for "air tight" concrete or something similar. Something like crack width or required thickness for the compressive zone. I have found requirements like that in the Eurocode for liquids but not for gas.
Thanks in advance.
Thomas
Thanks in advance.
Thomas
