Where used.............. 2
CAD2015
Computer
Jan 21, 2006
1,945
NX has a tool named "Where used" which unable users to find out where a Part belongs to(which assembly this component is part of).
How could I get in Catia information about a part's links to an assembly?
MZ7DYJ
this is more a plm than a cad function. so don't search in catia but in enovia (vpm, VPLM, ...) you will find your where used there.
Eric N.
I was wondering if Catia has a tool that would unable its users to get full informations about components and assemblies......
MZ7DYJ
You have to tell us which scenario are you using:
1. CATIA with a PLM system (as Eric said)
2. CATIA without PLM, files based on network/local hard disks.
What kind of info you want to get ? In first case all is there, a simple query will give you almost everything, depending on how PDM system was implemented and what you want to get...
For second case, I suppose you want to get info for files loaded in CATIA session?
Fernando
Hi Fernando,
Second case is my option that I'm expecting an answer from.
I am not required to use any PDM system on my daily Catia tasks yet.
MZ7DYJ
I need to know (as an exemple) what assembly use the part that I have opened.......
MZ7DYJ
You can find the path to part but I believe is not what you want...
OK, what you need is a workaround, there is nothing (as far as I know) like you want. Workaround would be to save all CATProducts like txt files (a script can be created to do it on a regular time based) then you can use Windows search to search inside all txt files what you want or...if you are aloud to use a File Manager like Total Commander or something similar you can search for a text string inside the folders where you have the catproducts....
Fernando
