which footing is better for such condition? 2
curiousinvite
42
Redline is boundary line ,footing cannot exceed beyound boundary line ,which footing would be most economical for such condition ?
Many footings have constraints like that but a concrete slab with thickened perimeter will work, or a sufficiently wide perimeter beam on its own with slab above.
You may consider inverted bowl foundation or grid foundation depending on the geotechnics , no. of storeys, frost depth etc..
curiousinvite said:
...which footing would be most economical for such condition ?
Depends on the loads. If loads are "light", I agree with others.
If loads are "heavy", probably a mat foundation (which will use more concrete, but avoid excessive expensive labor to form a complex grid).
Spans seem awfully short; if loads are not too bad, then a stiffened edge slab with stiffeners at the interior column locations (and possibly exterior column locations).
