All,
Given case here:
Steel special moment frame structure with concrete filled composite deck as rigid diaphragm. Which seismic force would you use to design the steel anchor studs between diaphragm and collectors?
After I searched ASCE 7-10 and 16, it seems that option 1 will be my answer.To confirm this, I went through 2012 IBC SEAOC structrual/seismic deisgn manual Vol.4 - Examples for steel-framed buildings. Page 250 uses option 1 to design anchor studs.
However, I'm not 100% sure, since the collector elements will be designed based on Option 2 - ASCE7-10 12.10.2.1, which includes overstrength factor. If the steel anchor stud on top of collectors does not have guaranteed capacity to transfer overstrength level seismic forces into collectors, why do we need to design collector elements for overstrength level forces? Can I explain this as such: seismic forces will somehow transfer not only through steel anchor studs, but also the bearing of column face to collectors/SFRS(seismic force resisting system), etc.?
Option 1: ASCE 7-10 12.10.1 Diaphragm design forces (the only possible amplification is due to irregularity (25%) from 12.3.3.4)
Option 2: ASCE 7-10 12.10.2.1 Load combinations with overstrength factor
Thanks.
Given case here:
Thanks.
