which valve is it
nabeel3
SA
Dear All
Which type of Valve is this? Combined Potable & Fire water Tank outlet ,14 inches dia . No drawings available.
Looks like a split body ball valve..
Gearbox suggested it is quarter turn (12 o'clock tag seems O for Open and 9 o'clock tag seems Close marking).
Quarter turn usually ball valve, butterfly valve and Plug valve.
Guessing it was pre 1980's.
Not sure if this is ANSI class or WOG. Won't be surprise if face to face dimension is not as per ASME B16.10 standard.
D
Danlap
The valve is 1989 make. Data
Actuator type: OV 300
Rotation: 90 degree
Turns:
Max Torque: 360 nm
Serial Number:
Constr Year: 1989
That's a ball valve.
What else do you need to know?
It's a ball valve. Looks like 14" 150# (Class 150) ASME/ANSI flanges to me. Interesting they installed the stem in horizontal here with the gearbox on it. May be the way to go to flush out any junk/debris every time it's opened/shut.
