Hello All,
Design Code - ASME B31.3
I have a dissimilar weld between API 5L X65 and A519 TP 4130 material coming in one of our jobs.
X65 has chemistry of 0.08 - 0.2% C, 0.15 - 0.4% Si, 1 - 1.35% Mn, 0.4% Ni, 0.3% Cr, 0.15%Mo
4130 has chemistry of 0.28 - 0.33% C, 0.15 - 0.35% Si, 0.4 - 0.6% Mn, 0.15% Ni,0.8 - 1.1% Cr, 0.15-0.25% Mo
I plan to use ER100S-G for GTAW and E101T1-G H4 for the above dissimilar welds. We had used the same for 4130 # 4130 welds.
A519 TP 4130 is unclassified material per ASME B31.3. I have referred API RP 582 (Just for reference) and 4130 has chemistry close 1.25 Cr,0.5 Mo and API RP 582 recommends to use the weld consumable which was used for 1.25 Cr, 0.5 Mo even for dissimilar welds between P1 # P4.
Let me know if the consumable I am selecting is correct or do I need to change it.
Thanks in advance.
Himanshu Naik
Thanks in advance.
Himanshu Naik
