In the dark days…
someone would want to start the generating set…
You would walk around the engine, look at all the guages, check everything was ok.
You would walk to the wall and start all the electrical auxiliaries.
Cooling water pump, radiator fans, building ventilation fans and so on.
Open the fuel valve; go to the air start and start the engine.
Afar it had settled at rated speed, 1500, 1000, 750 rpm in the civilised world (ouch!)
You walk around again and check everything, gauges, leaks etc.
Next you would move to the electrical control panel and turn the AVR control switch from off, to manual and then auto. You would check that the voltage was stable before synchronising the set to the mains
Now it’s all automated,
The sequence has not changed
