Why boat trailer always torsion axles and hydraulic brakes
Per one maker:
They are extremely efficient at providing suspension for single axle, tandem axle, and triple axle trailers. The installation in most cases is very simple, either U Bolting and Bolting directly to your trailers frame. With torsion axles, you will no longer need to worry about rusting Leaf Springs or Bolts, and your torsion axle will last you significantly longer.
This one has a lengthier explanation:
