Why flatness tolerance associated with a FOS must be less than the size tolerance? 1
Vincent PW
In my understanding, when a flatness tolerance is associated with a FOS, the Rule #1 is overridden and perfect form at MMC is removed. So, flatness tolerance associated with a FOS can be greater than the size tolerance.
However, ASME Y14.5-2009 specified in section 5.4.2 that, with flatness of a surface, where the considered surface is associated with a size dimension, the flatness tolerance must be less than the size tolerance.
Why must the flatness tolerance be less than the size tolerance?
Vincent PW, paragraph 5.4.2 states, "With flatness of a surface, where the considered surface is associated with a size dimension, the flatness tolerance must be less than the size tolerance."
That sentence lays out that we're dealing with surface flatness. The part saying that it's associated with a size tolerance just distinguishes a surface on a "feature of size" from a surface that might not be a FOS (in other words, not directly opposed from another surface).
But again, it's all within the realm of surface flatness. It's only when you get to paragraph 5.4.2.1 that they're talking about flatness on a feature of size itself.
That's because in an association with a FOS flatness is not controlling the flatness of a (singular) surface.
They are separate results from separate conditions.
This is correct but only for selected form tolerances applied to the size dimension or FOS. Same applies for straightness specified to the FOS but not the surface exclusively.
Excludes cylindricity...
When a flatness is specified to a surface it is a refinement of the surface, thus the limits of size Rule #1 is intact.
The size tolerance controls flatness. Why call up flatness when the size tolerance applies a tighter control?
Hi Garland23, thank you for your answer! Your answer has made my thinking smooth again.
As ghostdigital said, flatness specified to a surface is a refinement of the surface and it must be less than the size tolerance.
The only exception I can think of is that with a long plate, I can apply a flatness to the thickness dimension to override rule #1 and give it a bigger flatness tolerance.
(quote): "As ghostdigital said, flatness specified to a surface is a refinement of the surface and it must be less than the size tolerance."
But as I mentioned above, that's only true if the surface flatness is applied to a surface that is part of a "feature of size." If it's not, then paragraph 5.4.2 gives no requirement about having the flatness tolerance be less than anything.
On large, sheet metal parts and thin plates, I usually specify that the primary datum applies when the face is clamped to a flat reference surface. If your part is flexible, you need to manage the flexibility.
