Hi All,
My question is:
When designing an air vent to atmosphere for a ground or elevated WATER storage tank (i.e.: mounted on roof), what difference in performance can a pressure/vacuum relief valve make if the vent opening is made large enough to accommodate the needed exhaust of air during tank filling (or tank vapor pressure increase during solar heating) or to relieve vacuum during tank draining (or decrease in tank vapor pressure due to significant drop in ambient temperature)? My assessment is whether a PV relief valve is in place or not, as long as the vent design is sized large enough given all the parameters to consider such as tank wall thickness and material, diameter size of inlet and outlet pipes, air temperature/water temperature, tank manufacturer provided max P/V specifications and screen opening size, the vent should operate without tank failure due to overpressure or excessive vacuum.
I'd much appreciate other engineering opinions on this topic, thx!
LouC
My question is:
LouC
