Why this journal function works ?
Ehaviv
Computer
IL
Hi
I'm Confused because. I think
for this if
Code:
 If ItemAlreadyExists Then
   MsgBox("PartNumber Already Exists in TC")
 End If
This function shold work
Code:
  Public Function ItemAlreadyExists(ByVal item_id As String) As Boolean
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim item_already_exists As Boolean = False
    Dim database_part_tag As Tag
    ufs.Ugmgr.AskPartTag(item_id, database_part_tag)
    If database_part_tag = Nothing Then
      [b]item_already_exists = True[/b]
    End If
    Return item_already_exists
  End Function
And not this. (actualy in my test on nx manager this work. why?
Code:
    Dim item_already_exists As Boolean = True
      [b]item_already_exists = False[/b]
    End If
  End Function
Thank you in advanced
NxOpen API doc
Code:
UF_UGMGR_ask_part_tag (view source)
Defined in: uf_ugmgr.h
Overview
Finds the tag of a part in the database corresponding to the specified
part number.
In case of Default Domain: it is Team Center Engineering item ID.
In case of non-Default Domain: it is the multifield key.
e.g. ,=item_id=001, object_type=Document
,=item_id=001, object_type=SupplierPart, supplier_code=x
If the function is successful, the output
argument contains the database tag of the part. If the function is
unsuccessful, then the output argument is UF_UGMGR_null_tag.
Environment
Internal and External
Required License(s)
gateway
int UF_UGMGR_ask_part_tag
char * part_number,
UF_UGMGR_tag_t * database_part_tag
char *
part_number
Input
Part number.
UF_UGMGR_tag_t *
database_part_tag
Output
Database tag of the part corresponding to
the specified part number.
Code:
Overview
part number.
[b]If the function is successful, the output
unsuccessful, then the output argument is UF_UGMGR_null_tag[/b].
Environment
Required License(s)
gateway
char * part_number,
char *
part_number
Input
Part number.
UF_UGMGR_tag_t *
database_part_tag
Output
Sory. shold be.
Code:
If ItemAlreadyExists(PartNumber) Then
 End If
I was wrong in the above posts.
The right situation is as follows:
This routine return true if the
Part number already exists in TC (Tested on nxmanager)
But logically it seems that something
is rong because if part_tag = Nothing
its meaning is the part number have
not a tag and this means this part number
Not exist in TC.
Code:
    End If
  End Function
I reveal that
ufs.Ugmgr.AskPartTag(item_id,database_partag)
Not working at all because pattag always null
For any part number.
I found my mistake.
Part number should be
Without @DB/ and without revision.
