NickParker
What is the reason to reduce the LRC of the motor? Isn't the LRA inherent characteristic of a general purpose induction motor.
Why do some specifications insist to reduce the LRA, for example, to limit within 3-3.5 times of the FLA (Full load Amperes).
Is it to reduce the voltage drop at the bus during starting or to reduce the mechanical stresses of the driver/driven equipment?
Will it affect short circuit rating of the switchgear?
If LRA to be reduced, will it affect other parameters like Power factor, Efficiency?
