  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Wildfire 2.0 1
pbovat
11
I am running Wildfire 2.0. I have an assembly model and every time I open, the model one of my parts comes up hidden. I don't understand why that happens. I have to unhide the part every time I open it. I have saved it with the part unhidden, but still I open it and it is hidden again.
Help?!?!
Paul B
Still did not work!
Thanks though.
Then chances are your part is on a layer that is blanked.
Select the part and do a Right Click-->Info-->Feature.
The browser dealy will pop up and one of the tables will be for Layers. It should say it is on a layer and (if I'm right) shoudl say Operation = Blanked.
So now go into your Layers and either unhide the layer or remove that specific component from the hidden layer.
After all that, make sure you Save Status (as above).
Good luck!
