Blackberry77
I am doing a grounding study for a wind farm. The turbine areas have high resistivity layers (granite) and it is hard to obtain low step and touch potentials and GPR.
The system is as follows:
YY autotransformer with a buried delta
several mile long overhead collector line of ACSR with 5 turbines tapping off
OPGW interconnecting all ground grids back to the substation grid
I have modelled this in CDEGS considering the current I get from ETAP at each location. Is it advisable to use FCDIST for current splitting and how would I model this situation? Also, what methods could I employ to lower the step, touch, and GPR without driving ground wells. If I were to drive ground wells, how do I model this in CDEGS. I only have the MultigroundZ package.
Much thanks!
Much thanks!
