I am developing the wind loads on A-frame residential structure, dimensions 23'x25'x20' (Length x Width x Height). The project is located in North Carolina and the reference standard for wind load is ASCE 7-10. Although there is no a specific mention of A-frame structures in the standard, it appears there are at least 2 choices for determining the wind loads for the Main Wind Force Resisting System (MWFRS), which are:
i. Chapter 27, Part 2: Enclosed Simple Diaphragm Buildings With h <= 160 ft. The User Note states "Part 2 of Chapter 27 is a simplified method for determining the wind pressures for the MWFRS of enclosed, simple diaphragm buildings whose height h is <= 160 ft. The wind pressures are obtained directly from a table. The building may be of any general plan shape and roof geometry that matches the specified figures."
ii. Chapter 28, Part 1: Enclosed and Partially Enclosed Low-Rise Buildings. The User Note states "Use Part 1 of Chapter 28 to determine the wind pressure on the MWFRS of enclosed, partially enclosed or open low-rise buildings having a flat, gable or hip roof."
The A-frame structure is essentially a gable roof with a roof angle (theta) of 58 degrees (from horizontal) mounted on a very low wall/curb. I plan on mounting the roof on a knee-wall around the perimeter of a slab-on-grade foundation to keep the edge of the roof at least 18-24 inches above finish grade.
I would appreciate comments on whether or not it is appropriate to consider the A-frame structure as a "simple diaphragm building", which would lead me to use Chapter 27, Part 2 to obtain the wind loads on the roof. I will include some wind load on the knee-wall, but the majority of the surface area would be the gable roof with a steep angle. Chapter 28, Part 1 does not mention the necessity of having a simple diaphragm and would seem to be a method that would not be questioned in terms of applicability, even with the low wall height.
Thank you for any responses or comments.
