Fleabagger
Hi all!
I am designing a foundation for a light pole whose diameter at the bottom is 205mm and 114mm at the top. The pole section is tubular of 5mm thickness and the light pole is 10m high. The lights are 500mm x 430mm. I would like to know the force coefficient I should use in the estimation of wind load on the light bulbs. Would it still remain 1.8/2 which is usually the Cf of a rectangular section? Or is there any clause in ASCE which lets us bypass this rule thereby allowing us to estimate the wind load using a smaller value of Cf?
Thanks!
Thanks!
