SYLK
- Mar 18, 2023
- 18
I need help with the wind load concept. I am a civil engineer but not working in building structures. I am designing an elevated open steel structure to install solar panels for my home. The structure is 13 feet tall and is mono slope roof at 29^. I used ASCE-16 and got a horizontal wind load of 21.68 psf and that translates into 24.79 psf normal to the solar panels. Is the uplift forces also 24.79 psf?
The structure is supported by 6 posts (2 rows 3 bays). Is the uplift resistance analysis based one column or all together? Is the uplift resistance force the tributary Dead load plus the weight of the foundation?
Thanks.
Also how would I consider whether seismic base shear or wind load is the critical load? Thanks
Thanks.
