SYLK
- Mar 18, 2023
- 18
I am designing an open mono-slope structure and have the MWFRS & C&C wind pressures calculated.
I took the wind pressures from C&C and multiply the zone areas with their respective area pressures, adding the zones downward forces and zones uplift forces individually, I obtained the total downward force and uplift force for the entire building.
I have 6 columns in 2 x 3 configuration. That means the two central columns would carried twice the load (by tributary area) of that by each of the other 4 columns. I am designing an isolated footing to support each column loads.
Here are my questions. 1.) Why is the uplift load combination 0.6+W ?
My confusion is: Dead Load is downward force and the uplift force is upward force, and adding the 0.6D to W would increase the upward force: say, my wind uplift force is 3000 lb and my superstructure DL is 1000, that would mean 600+3000 = 3600lb. Should we subtract 600 from 3000?
2.) My 3000 lb uplift force is from C&C and is an LRFD load. That need to be changed to 3000 x 0.6= 1800 to ASD's, correct? Then 0.6D + W is = 600 +1800 = 2400 lb - that is the uplift force for the foundation design?
