What is the method of calculating an uplift capacity of a single 1/2" or 3/4" puddle weld from a metal deck to a steel members subject to a net uplift force due to wind.
Say calculated wind uplift is 40 psf, DL on the deck is 15 psf, deck is 20 ga B-Deck (1 1/2"
, welds are at 12"oc at the supports, typical beam spacing is 8'-0" oc. Net uplift to resist would be 40 - 15 or 25 psf.
Connection will be not be a problem by inspection but for a rigorous check what would we do? Thanks for the advice.
