window 98
yongheekim
14
CA
Hello folks,
I have encounterd the following problem despite installing Window 98 successfully.
" Cannot find a device file that may be needed to run Windows or a Windows application.
The Windows registry or SYSTEM.INI file refers to the device file, but the device file no longer exists.
If you deleted this file on purpose, try uninstalling the associated application using its uninstalled or setup program.
If you still want to use the application associated with the device file, try reinstalling that application to replace the missing file.
vnetsup.vxd."
Frankly, I don't know how to solve this problem so I really appreciate it if somebody helps me to solve the problem.
YONG HEE KIM
