SoFloJoe
- Apr 3, 2018
- 76
Hi All,
I understand that I maybe grasping at straws here, trying to make something work that on paper does not.
My client is a window installer and has an opening roughly of 15ft. It has a standard 96" in high sliding doors at the bottom and on top is a 70"high fixed window setup. In between the windows requires a support beam to provide a structural connection for both the sliders below and fixed above. Attached is a photo
I am doing a simple beam calc and focusing on wind loads, currently at the max which is the -37psf (with 0.6 ASD Load combo already applied). Tributary height about 85".
Doing a simple beam calc I am getting an overall moment of 950 kip-in and my Sx requirement w/ 0.65 SF applied to a 50ksi yield strength is +/-30 in3 (the beam would be rotated 90 deg in the direction of the wind). I am not worried about moment of inertia since there should not be any deflection here due to windows below and above the beam.
BUT, with such a high section modulus my beam dimension is too large I need to stay within +/-6"x4". I feel like I might be going too conservative with my calcs. Is there a reduction allowance or different method of approach to make the Sx go down?
Thanks for your help!
