astronomer
Aerospace
- Jun 8, 2005
- 25
I need to find a 2.5 mm thick BK7 window, both sides AR coated (400-1000nm), flatness lambda/2 or better and surface 20/40 scratch/dig or better. The shape and size of the window is not important as long as it is bigger than say 15 mm. The problem is that I need only one. I have a $2160 quote which is a BIT on the high side.
Thanks.
Thanks.
