wizard CAM
berri
102
I have a question, can I customize a template with different colour for each milling, drilling operation, and used it in wizard session?
for example red color in the piece, mill planar, blue color, ramping etc.
thanks.
You can set the color for the tool path motions in the Operation or in the Method. Once they are set in a template that will be the default color.
Select Options - Edit Display - Path Display Colors
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
NX5,6, 7 Solid Works, Solid Edge
