Dannnnnny
- Jun 9, 2020
- 9
Hello all,
need help in figuring out reinforcement approach to one of mandatory soft-story projects that i'm handling now.
So it's a 4-story building and I'm trying to reinforce one of sides with wood shearwall.
However, since I can only place shearwall one side, i.e. outside, as placing shearwall inside gets complicated due to presence of tenants, I can't seem to meet the requirement. I believe I should consider using moment frame, but I was wondering if using thicker plywood could increase allowable shear diaphragm values.
SDPWS2015 only provides the values up to where 19/32" plywood is used. So does that mean I won't be able to use thicker plywood by code? If I ever could do so, any idea where I can maybe find those related information?
I flipped through SDPWS, CBC and NDS but couldn't find solid solution to this.
Thanks in advance!
Thanks in advance!
