Haldorson
- Mar 27, 2011
- 92
[NFPA 13 (2013)] A combustible concealed spaced is created by fastening drywall tight to the bottom of a wood truss system. The wood truss has less than a 6-inch gap between the top of bottom chord and bottom of top chord.
Are sprinklers required within this combustible concealed space, or does 8.15.1.2.3 and the 6-inch limit apply to both 'double joist" construction and wood truss construction?
If sprinklers are required, I note the combustible concealed space sprinklers - ie Tyco Model CC3 or Reliable KFR-CCS 56 - have a minimum gap between the top of the bottom chord and bottom of top chord of 6-inches. These sprinklers are not listed for this case where it is less than 6-inches, so are we limited to standard coverage sprinklers in every channel?
