During an In process inspection of supplier the third party inspector found the supplier using ER70S-6 instead of the WPS specified ER70S-2 filler metal. The supplier agreed to remove the S-6 and reweld with the required S-2. My question is will this be justified NCR on supplier? I know the S2 and S6 have the same F# and SFA # tensil stregth is like 10k difference and then you have the fact of re welding.
