Wrap text
sasha1
Aerospace
Feb 5, 2008
54
Ive been asked if we can write text and align it to an arc?
Any help would be much appreciated
Then you can use Insert - Curve – Text and set the Type to On Curve.
If you are looking to create a “note” on a curve then you will need a UG open program to do that. There is a GRIP program available in the international GRIP library at the plm world website. – membership is free and you can download from
The program is called o_text
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
Note an arc is by definition planar so the text will line in the plane of the arc. If you want to wrap planar text around a cylinder or cone then try Insert>Curve from Curves>Wrap/Unwrap.
Cheers
Hudson
