palk7 EIT
- May 12, 2020
- 159
When having a X roof bracing designed only to be a Tension only bracing. With that member being an L angle section it's possible that due to stiffer member it can take a Compressive axial load. If it takes a Compressive load then the lateral displacements of the portal frames are enormously huge when compared to modelling those X braces as tension only braces. Has any one experienced this before?. If so how to ensure that the L angle cross bracing works only as a tension only member and doesn't take Compressive force. Cuz of a longer span I had to go with A little heavier angle to avoid too much deflection under its own weight and since it's heavy it could be susceptible to take Compressive load as well creating huge lateral displacement.
Thank you
Thank you
