XREF problem
Dymalica
I use ACAD 2002 or 2008, both have the same problem. I open an XREF and the drawing shows up. I open a file and insert XREF and it doesn't show up. I regen and everything, and nothing comes up. It doesn't say the xref is attached for some reason also. This seems to happen when I get XREFs from architects. Please help, I am going grey over this problem.
did you use the same units?
Layer ok?
Can you see the xref in the Xref-Manager?
Which software are the architects running?
Lothar
ADT 2004
