After getting paperspace/modelspace under my belt along comes xrefs and it all starts again. Right the question is this. Large drawing 4 floors turned into flats and I need to install all the new bathrooms. Now I have got the reason for xrefs eg to keep file size down with mutiple blocks adding up etc. Do I make a new drawing up for each floor by copying the wall layouts from the original drawing and then insert the sanitary blocks on the new drawing then with the new drawing xref that to the original. ? do I need to remove the walls on the new drawing or use them as a ref point and overlay onto the original.Hope that gives an idea of my problem.
Looking forward to any answers
