b10m3ch
Bioengineer
- Jul 18, 2019
- 5
Hello all,
I am in the preliminary phases of designing a bioreactor capable of withstanding pressurization up to 25 MPa ( i would like 50 but given some of my other design requirements i wont press my luck). I would like a safety factor of 3 so basically I am designing something to tolerate 75 MPa internal pressure. I know steel would be an obvious choice for this application but I would like to use a clear material high strength polymer if possible for movie recordings of that action within the vessel. The vessel will be exposed to pressure cycling (~10 hz max) and ambient temperatures of 37C, which are added points of complexity.
On the bright side the vessel will be a small cylinder (working volume ~ 5cm tall & 5 cm diameter).
I want to know if there are any new materials that are translucent but have structual properties to not just explode under these conditions. I am going to verify with FEA of course and do test pressurization prior to use but I would like to set myself up for success by getting my starting material right.
Thanks in advance.
Thanks in advance.
