Ultra Strong Plastic
zigzag4
Computer
Aug 20, 2004
4
Can someone recommend a type of plastic that could be used to replace a steel component that's 0.5mm thick?
It has to be:
1. As strong as steel
2. Able to resit warping between 10-80 degrees C
3. Currently available commercially
4. Relatively cheap
5. Able to be formed into an exact shape
Many thanks
Plastic conversions from metal tend to have distinctive characteristics like:
- near constant thickness design;
- gussets on one or more sides;
- undercuts.
What may appear simple can become a nightmare. Get expert consultation from plastic manufacturers and molders.
Many thanks - I'll bear this in mind.
Since posting I have been told that PEI / POM might fit the bill but mouding will be prohibitively expensive - therefore the item would have to be cut from sheet.
Heres a link with full comparative specs given by a German maufacturer
