how to increase speed of working?
iraniii
Automotive
Sep 18, 2004
37
please inform me about
memory, graphics card, ...?
or settings in catia?
The answer is yes, to all of the above. Let us know the specific area you are having trouble with, and we can make suggestions.
Your processor affects the "speed of working" more than anything.
Like catiajim noted, though, what are you looking for specifically?
The video card will improve dynamic rotation performance, etc. CATIA should be used with an OpenGL card such as an nVidia Quadro or a 3DLabs Wildcat. You can also crank down the visualization settings.
Memory... CATIA wants to use a lot. If you are working on extremely large assemblies, you should absolutely work with cache enabled, and you should invest in a solid 2-3GB of system memory (and use Windows XP).
Can you tell us about your work station ? If you are using a regular computer you should try a CATIA certified one.
Then explain us what you do with CATIA... very large Assembly? VERY large and fully parametrized Part? Stress Analysis ?
Eric N.
catiav5@softhome.net
