GIGI72
- Jun 9, 2004
- 7
We are going to manufacture some covers for heat exchangers with drain and vent threaded connections placed on the short radius of the knuckle of the formed head.
Can someone tell me if ASME VIII div. I accept this openings in this position? Consider also that the coupling is always less then 1" dia. NPT-F, welded with fillet as per UW16.2.
Thank You.
Thank You.
