sbw
- Sep 20, 2004
- 30
I'm trying to determine the maximum allowable external pressure on a 54"x0.375" and a 54x0.5" welded steel pipe (grade A36). Specifically, the pipe is capped at the bottom standing in water, so I'm trying to determine maximum allowable depths for the external hydraulic head. Ordinarily I'd order the relevent design manuals, which in this case I believe to be AWWA M11 and AISI vol 3, but I've been asked to respond by tomorrow a.m.
Can someone direct me to on-line design criteria or software that I can use in this pinch? (I've already used the 30-day 'free' trial on the AISI software).
