Remove tool from CATProcess
efortin
5
I'm working on a Process Document (CATProcess) and would like to programmatically remove a ManufacturingTool from the document. I record a macro but as usual, the macro generated by Catia is unusable (what's the point of having a recording facility if the recorded macro can't be used?!?!?!?!?).
Does anyone here knows what sequence of instructions I have to use to remove a tool from the list of resources in the PPRDocument? I can't find any Remove method related to resources in a PPRDocument in the documentation.
Thanks in advance for all your help,
Etienne Fortin
