Adding commands in a workbench
vaibhavcatia
Automotive
Oct 4, 2004
1
Hi all,
While I am using sketcher /part design workbenches, i frequently need to use some commands which are not in the pull down menu. I tried using "view>command list" and from there tried to run the commands. This works, but is time consuming every time to use "view-commandlist"option .
I was wondering if there is any way I can add the commands I want to the workbench that I am working in??
Vaibhav
You can create your own Toolbar and add function to it using the tools/customize function. You should try that when you define your ENVIRONMENT.
If you want more specific stuff like new menu then check CAA ($$$$$).
Eric N.
catiav5@softhome.net
