Draft Anlisys on Solids or Class A Surface in V5
EEEmery
Automotive
Has any had any luck with draft analysis of a solid or class A surface? Does any one now if you can perform daft analysis on a class A surface and in what work bench you need to be in to perform this? Those of you using draft analysis is it useful or is it difficult to translate the results?
Hi EEEmery,
Sounds like we can have such functionality of adding our customised (non-standard) Drawing format in Standards from R14. Let's see ...
Cheers. Kennis.
Sorry EEEmery,
I post my reply in the wrong thread.
Cheers. Kennis.
