JohnFortier
- Aug 11, 2003
- 33
I'm thinking of combining the Aceair with a small - 1000lb thrust - Williams turbofan.
Simple question I know, but since the Aceair normally uses a 110 HP rotary wankel engine, is there an easy correlation between HP and lbs thrust.
Another question on the same general subject; the Aceair has a "do not exceed" speed of 200 knots. Assuming that this is a drag limit, beyond which the airframe becomes either unstable or the drag exceeds the safe strength of the airframe, will this "do not exceed" speed increase with altitude. The Williams will operate to quite extreem altitude, and assuming that I fit the aircraft with oxygen equipment, so that the control system doesn't pass out, will I be able to increase the cruise speed at these higher altitudes.
I'll be assembling the aircraft inthe UK, so CAA regulations will apply. Definitely an experimental aircraft!
I'd appreciate some advice here, since it strikes me that a small turbo and the Aceair would go very well tgether.
John
John
