I am required to convert the engine from RAW water cooling to a CLOSED cycle system. 220 hp @ block temperature of 160F, engine pump discharge I.D. is 2.0". We would like to stick with a SS shell and tube, Please specify the outer O. D. and GPM with a open intake and discharge on the floor of a boat. Can it be done with a length of 8' or less. Lake water is a maximum of 85F. Since my field is electronics, I am asking for help. I can not even make a guess of the actual heat loads involved.
