Merzi
- Dec 12, 2002
- 50
We are fabricating a Pressure which had repads for nozzles and manways. These repads are cut in two pieces and fitted on the nozzles after the full penetration category "D" joint is welded and PT tested. two tell tale holes are also drilled.
After welding the repads, we carry out a 15 Psi Pneumatic test on the pad. It was observed during one of our test that while applying pressure to check one side of the repad, air was coming out from the other tell tale hole. There were no leakages in the weld fom inside and outside.
My question is what is the reason of the air coming out from the tell tale hole when the two halves of the pads are welded
