Kryanl,
Back from the holidays.
The equation you are referring to is in section 2.2.5.2.5 of NFPA 30 which is referenced as the source for the required venting given in UL-142. While UL-142 references NFPA-30 I don’t think UL-142 allows you to reduce the UL-142 venting requirement based on a formula in NFPA-30. So, if you have to comply with UL-142 then you must meet its provisions regardless.
But if you don’t have to meet UL-142 and you want to use NFPA, then you could use the formula. The way I read NFPA, the formula “shall be permitted” to be used in lieu of the tables preceding it. I think there intent is to allow a reduction in the venting capacities if the designer is willing to take a more rigorous approach. In other words, I think all you have to do is meet either of NFPA 2.2.5.2.3 or 2.2.5.2.4 but if you wanted to do the additional work, you can reduce the requirement using the formula.
Personally, I would not use the formula. First off, it isn’t worth it. Say your tank is 12’ x 48’ long. Then I get an area of roughly 2,033-sqft. So the venting requirement is about 600,500-CFH and UL-142 would require a 10” vent. If you apply the formula for diesel fuel (see below for properties) then you get 40,143-CFH and UL-142 would require a 3” vent. By the time you add in the cost of labor, the hot work permits, the equipment, consumables, etc.. I don’t’ think the difference in cost between installing a 10” nozzle is that much more than installing a 3” nozzle. The second reason I wouldn’t do it is because NFPA allows the formula reduction for a “specific” product. If you ever changed the service of the tank then you would have to re-evaluate the vent.
But to answer you question, I only found information for Diesel. I found it on a web site for Ethanol which had a table of properties of fuels. It gave the molecular weight of 200 and a latent heat of vaporization of about 100-btu/hr. Of course the reason it’s so hard to find this information is because fuels vary widely in their properties. I could take a gallon of diesel here in Tampa and a gallon from say New York, and get different numbers for both.
Hope this helps.
Ken Hardy
Tampa Tank
