pvesseleng
- Dec 19, 2004
- 51
Hi Everybody,
If any vessel it has Category A, B, C welds as illustrated in Fig. UW-3.
With customer approval RT requirements as described in UW-11 satisfied by Automatic Ultrasonic Test (AUT) Method according to Code Case 2235-6.
But, some of the nozzle exceeding either NPS 10 or 1 1/8 (29 mm)wall thickness (which are require radiography for their full length) couldn't be made Automatic Ultrasonic Test because of in some weld seems its not applicable to make AUT. For that reason this nozzle welding has radiographically examined.
According to Code Case 2235-6 it has to be stamped ''UT''. But some of the weld seems RT examined.
and
in UG-116 (e)(4) states that nameplate should be marked ''RT 4''when only part of the vessel satisfied the radiographic requirements of UW11(a)or where none of the markings ''RT1'',''RT2'' or ''RT3'' are applicable
Q1)How ASME nameplate has to be marked(for NDT) only UT or UT-RT4
Q2)on U1-A Form how this situation has to be mentioned.
and
