qctom2005
Industrial
- Dec 28, 2004
- 4
I have taken over as QA/QC manager and are on process of reviewing the PQR's and WPQR's and have a few questions....
I have a Procedure Qualification Record that shows a 6.625" Dia pipe with a thickness of .432" was used which inturn limits me giving a welder performance qualification test to nothing below 2.875" OD and nothing below .1845" or above .864" in thickness.... Is this correct or am I reading the code wrong?
I have some guys that were test, before I took over, with this procedure but the actual values of the test coupon were only 2.375" Dia with a thickness of .436" which by QW 451.1 the welder should be qualified for thickness down to .1845" and up to .872" and a dia of >1" to Unl. but QW Is this correct or is the Welder Performance Qualification Void? This is out of the PQR data
