arcer
Materials
- Dec 30, 2004
- 31
When attaching hemi heads which are thinner than the shell plate, some fabricators cut back the hemi head and taper the shell plate to the head thickness ( 3: 1), while others put the hemi head, without cutting it back, on the shell plate, and use weld metal to provide the required taper. Is there any advantages to one over the other? How is it possible to reduce the shell thickness of the shell without compromising it's integrity?
