Solve For Position
kayakeng
I'm new to MathCAD and can not seem to get the syntax correct to solve for the x-y position of a link as it rotates about a point. Can any one help with setting up the array to solve for each position as theta is incremented by x degrees?
Never mind. I've figured out how to solve the equations.
Strange, isn't it, how you always seem to solve a problem for yourself 5 minutes after you ask somebody else (or worse still, the answer dawns on you as you ask the question).
Bung
Life is non-linear...
