jasoncc
Materials
- Jan 20, 2005
- 3
If a welder can test using C/S material (P1), and a carbon (F6/A1) filler wire, this qualifies the welder as per ASME IX to weld P8 S/S material using F6 S/S filler wire.
I feel this is not good practice as the welder has not shown ability to clean wire/test piece, maintain temperature, purge test piece, or the skill to manipulate S/S wire.
If this is regarded as bad practice/workmanship, or an unsuitable test for use on corrosion resistant S/S pipework, can the third party refuse to accept this method of testing as being siutable, with technical backup showing why the test is inadequate, because ASME is only a guideline for good prractice?
Or do the certifying authority have to accept and endorse something which may be of questionable technical and practical practice, because the specification says that it is ok?
