Best grade of Stainless Steel for a blade 1
PatCouture
534
Hi, I need to make a blade using stainless steel, but I'm not sure which grade to use, It will be a rotary blade for cutting nylon nets and it can hit some metals at time.
Thanks for the help
Patrick
440C, or some variation of it, is very common cutting edge material.
If you are talking about hitting small pieces of metal then you will get some chipping, if you mean solid metal you will need to keep the hardness lower in order to improve toughness.
Select the temper temperature that you need.
Corrosion never sleeps, but it can be managed.
Thank you guys! That was very helpful.
Patrick
Why not put a TiN or other hard coating on the blades? We make and coat stainless steel blades on a regular basis (bone saws, scalpel blades) and the life increase is rather dramatic. Most bone saws barely make it through one total knee replacement. Ours last through two or three (autoclaved between operations, of course).
Jim Treglio
Molecular Metallurgy, Inc.
The razor blades used to chop fibers for use as fill in plastic are 440C(mod) TiC coated.
The reaction uses the C in the alloy and Ti in a gas to form a surface of TiC that is part of the blade.
Under normal conditions the blades are a '10' as honed and due to the combination of wear and corrosion (residual acid in the fibers) they wear down to a not usable '4' in about 4 hours.
The coated blades are a little less shart, only an '8' to start with, but they last 6-10 times as long before they are too dull to continue.
