Parabolic spring loading
Starchief
Automotive
Mar 22, 2005
5
I need to find the test load for a parabolic spring that is part of a truck suspension. It is loaded at approximateley 60/40 with 60% load on the parabolic end. The axle load is 31,000 lbs. What load should I use to fatigue test it?
